§ 1.2 Abbreviations and symbols FAR (14 CFR)
The FAR’s (CFR’s) are continuously being updated. Those updates are not automatically reflected here on Pilot Ground. Please refer to official sources for the most up-to-date information. The following post is intended to organize conversations about the specific FAR mentioned. This post is not intended to be used as an up-to-date reference. With that being said, if you find that this FAR has been updated, and the update is not reflected here yet, (or you find an error) please mention so in the reply’s below and tag one of our Moderators or Administrators so that we can keep this as up-to-date as possible. Nothing in this Topic/Post or anything in the Reply’s is legal advice. If you require legal advice, please seek your own council elsewhere.
PART 1—DEFINITIONS AND ABBREVIATIONS
Authority:49 U.S.C. 106(f), 40113, 44701.
§ 1.2 Abbreviations and symbols.
14 CFR 1.2 | FAR 1.2
In this chapter:
AFM means airplane flight manual.
AGL means above ground level.
ALS means approach light system.
APU means auxiliary power unit.
ASR means airport surveillance radar.
ATC means air traffic control.
ATS means Air Traffic Service.
CAMP means continuous airworthiness maintenance program.
CAS means calibrated airspeed.
CAT II means Category II.
CMP means configuration, maintenance, and procedures.
DH means decision height.
DME means distance measuring equipment compatible with TACAN.
EAS means equivalent airspeed.
EFVS means enhanced flight vision system.
Equi-Time Point means a point on the route of flight where the flight time, considering wind, to each of two selected airports is equal.
ETOPS means extended operations.
EWIS , as defined by § 25.1701 of this chapter, means electrical wiring interconnection system.
FAA means Federal Aviation Administration.
FFS means full flight simulator.
FM means fan marker.
FSTD means flight simulation training device.
FTD means flight training device.
GS means glide slope.
HIRL means high-intensity runway light system.
IAS means indicated airspeed.
ICAO means International Civil Aviation Organization.
IFR means instrument flight rules.
IFSD means in-flight shutdown.
ILS means instrument landing system.
IM means ILS inner marker.
INT means intersection.
LDA means localizer-type directional aid.
LFR means low-frequency radio range.
LMM means compass locator at middle marker.
LOC means ILS localizer.
LOM means compass locator at outer marker.
M means mach number.
MAA means maximum authorized IFR altitude.
MALS means medium intensity approach light system.
MALSR means medium intensity approach light system with runway alignment indicator lights.
MCA means minimum crossing altitude.
MDA means minimum descent altitude.
MEA means minimum en route IFR altitude.
MEL means minimum equipment list.
MM means ILS middle marker.
MOCA means minimum obstruction clearance altitude.
MRA means minimum reception altitude.
MSL means mean sea level.
NDB (ADF) means nondirectional beacon (automatic direction finder).
NM means nautical mile.
NOPAC means North Pacific area of operation.
NOPT means no procedure turn required.
OEI means one engine inoperative.
OM means ILS outer marker.
OPSPECS means operations specifications.
PACOTS means Pacific Organized Track System.
PAR means precision approach radar.
PMA means parts manufacturer approval.
POC means portable oxygen concentrator.
PTRS means Performance Tracking and Reporting System.
RAIL means runway alignment indicator light system.
RBN means radio beacon.
RCLM means runway centerline marking.
RCLS means runway centerline light system.
REIL means runway end identification lights.
RFFS means rescue and firefighting services.
RNAV means area navigation.
RR means low or medium frequency radio range station.
RVR means runway visual range as measured in the touchdown zone area.
SALS means short approach light system.
SATCOM means satellite communications.
SSALS means simplified short approach light system.
SSALSR means simplified short approach light system with runway alignment indicator lights.
TACAN means ultra-high frequency tactical air navigational aid.
TAS means true airspeed.
TCAS means a traffic alert and collision avoidance system.
TDZL means touchdown zone lights.
TSO means technical standard order.
TVOR means very high frequency terminal omnirange station.
V A means design maneuvering speed.
V B means design speed for maximum gust intensity.
V C means design cruising speed.
V D means design diving speed.
VDF / MDF means demonstrated flight diving speed.
VEF means the speed at which the critical engine is assumed to fail during takeoff.
V F means design flap speed.
VFC/MFC means maximum speed for stability characteristics.
VFE means maximum flap extended speed.
VFTO means final takeoff speed.
VH means maximum speed in level flight with maximum continuous power.
VLE means maximum landing gear extended speed.
VLO means maximum landing gear operating speed.
VLOF means lift-off speed.
VMC means minimum control speed with the critical engine inoperative.
VMO/MMO means maximum operating limit speed.
VMU means minimum unstick speed.
VNE means never-exceed speed.
VNO means maximum structural cruising speed.
VR means rotation speed.
VREF means reference landing speed.
VS means the stalling speed or the minimum steady flight speed at which the airplane is controllable.
VS0 means the stalling speed or the minimum steady flight speed in the landing configuration.
VS1 means the stalling speed or the minimum steady flight speed obtained in a specific configuration.
VSR means reference stall speed.
VSRO means reference stall speed in the landing configuration.
VSR1 means reference stall speed in a specific configuration.
VSW means speed at which onset of natural or artificial stall warning occurs.
VTOSS means takeoff safety speed for Category A rotorcraft.
VX means speed for best angle of climb.
VY means speed for best rate of climb.
V1 means the maximum speed in the takeoff at which the pilot must take the first action (e.g., apply brakes, reduce thrust, deploy speed brakes) to stop the airplane within the accelerate-stop distance. V1 also means the minimum speed in the takeoff, following a failure of the critical engine at VEF, at which the pilot can continue the takeoff and achieve the required height above the takeoff surface within the takeoff distance.
V2 means takeoff safety speed.
V2min means minimum takeoff safety speed.
VFR means visual flight rules.
VGSI means visual glide slope indicator.
VHF means very high frequency.
VOR means very high frequency omnirange station.
VORTAC means collocated VOR and TACAN.
[Doc. No. 1150, 27 FR 4590, May 15, 1962]
